First Generation Honda Civic 1973-1979 Increase Power Menu
Index Page Bolt On Mods Cylinder Head Mods Bottom End Mods Engine Swaps Performance Parts
Main Menu 1200 Build 1 1200 Build 2 Induction Options Distributor Mod
 1200 Distributor Upgrade
(Honda Electronic), 1200 Electronic Upgrade
Second Generation Electronic Distributor Conversion
This distributor is from the second generation Civic. It is an electronic distributor and doesn't use points. You also need the wiring from the same car and the coil. Do not use a ballast resistor with the new coil and be sure to gap your plugs as a car with electronic ignition (.040 I think)
If you are converting to a second generation distributor, be sure to use an extra mounting plate at the bottom to make up for the longer shaft. The one from your old distributor will work but they will line up differently, get a 2nd generation one and they will match. As for wiring, If you pull one from the junkyard, mark the wires and where they go as you remove the harness. It's best to get the coil with it so you don't have to disconnect it, and just take the coil and related wires off of the main harness. It is easier to have the wires installed and then replace the coil than it is to deal with a mess of loose wires.
I just finished putting the 2nd Gen electronic dizzy on my 74. When I pulled it from the car at the yard, I grabbed the whole system, but cut the line leading to the fuel pump. When I put the electronic dizzy into my car I had to use not one but TWO extra spacers to make it exactly the same length as the old points dizzy. The plate that comes with the electronic dizzy is different than the points dizzy plate. Because of this I had to do some custom drilling to the extra plates to enable me to get the full Advance/Retard motion. It's nice to know I will never have to adjust points. Bomber system. Buy a new cap and rotor, buy fresh plugs, buy new coil and dizzy leads for the system too. Gap the plugs at 039 to 041. Remove the Ballast resistor, and connect this lead to the coil.
Drawing showing the connector connected to the coil.
EN1 Distributor wiring diagram for a 1200 swap
This setup does not require spacers when using the EN1 dizzy.
Wiring is different if using EJ distributor and spacers may be required
The EN Canadian dizzy is a bolt in, however you need some kind of external control module to make it work. The EN only has a magnetic pick-up in there unlike the US has the pick-up and igniter built into one.
Link to discussion forum topic
