Weber single and Dual 40 DCOEs
A&T
Engineering Dual Dellorto
A&T
Engineering manifold for DGEV
Weber
28 DCD
Weber 32/36 DGEV
Keihin
CR Special 35mm quad carburetors
Dual
Keihin Carburetor for RS Intake Manifold
Fuel
pump and regulator
Adjustable
cam pulley
Adjustable Cam Gear 1200
Check Discuss 1200 for a run on these
Norris
Cam shaft. Designed for big volume but is still good for street use.
Norris
timing gauge
Cam
drive dizzy for race head
Lightened
flywheel
Control
arms with special bushing for negative camber, but only about 1 degree.
Roll
bar (SCCA approved)
Mugen
EB Valve Cover
C8
3-piece Panasport race rims, 7x13, 120 PCD with old Yokohama T-452 slicks
S&S Header
Most pictures courtesy of Ted
