1200 Civic
Service Information
(Non-CVCC) |
Lubricants
Engine
5.3pts or 3 Litres
Castrol GTX
Gearbox
Manual Transmission
4.5 pts or 2.5 Litres
Castrol GTX
Hondamatic
Castrol TQ Dextron
Wheel bearings
Castrol LM Grease
Engine
1169cc
1238cc
Capacity
71.4cu in.
75.5 cu in.
Bore
70mm
72mm
Stroke
76mm
76mm
Compression Ratio
8.1:1 (8.3:1 USA)
8.1:1
Rotation
Anticlockwise
Viewed from the pulley end
Valve Clearances
(Cold)
USA
type (Inlet & Exhaust)
0.13 – 0.17
(0.005-0.007)
Other types (Inlet &
Exhaust)
0.10-0.14
(0.004-0.006)
Valve numbering sequence (from timing belt end)
Inlet Valves
1,3,5,7
Exhaust Valves
2,4,6,8
Cooling System
System
capacity
4.2lirres (4.4 quarts
us)
Fan
operating temp
88.5deg-91.5deg cel
(176deg - 183deg f)
Fuel
Fuel pump pressure
2.5lb f in2
0.18kg cm2
Fuel tank capacity
37.8L (10US gallons)
Spark Plugs
1169cc
1237cc
NGK
BP-5ES, BP-6ES
BP-6ES
Denso
W-20EP, W-20EP, W-22EP
W-20EP
Gap
0.7-0.8mm
(0.028-0.031")
0.7-0.8mm
(0.028-0.031")
Firing Order
1,3,4,2
No 1 cylinder being
at the timing belt end
Gear box Ratio
Manual 4 speed
Hondamatic
1169cc
1238cc
1st
3.00:1
1.521:1
1.636:1
2nd
1.789:1
1.034:1
1.034:1
3rd
1.182:1
4th
0.846:1
Reverse
2.916:1
2.045:1
2.045:1
Tires
600s 12-4PR
24psi all around
Front wheel
Alignment
Castor
1Deg 45'
Camber
30' positive
Toe
Out 1mm (0.04")
Rear Alingment
Camber
30' positive
Toe
Zero
Brakes
Disc Brakes
Thickness
Service limit
9.6mm (.03780)
9.0mm (0354)
Drum Brakes
Internal Dia
180mm (7.086")
181mm (7.126")
Hand Brake
Adjustment
1-5 notches on lever
Brake Fluid
SAE J1703 or DOT 3,4
Electrical
12V - ground
Battery
20hr @ 32 or 45 amp
hour
Alternator
12V
14V @ 1200rpm no load
14V@ 5000rpm 35amps
if air 820rpm
Voltage Regulator
13.5-14.5 volts
Weights (kerb)
1973-1974 Manual
1621lb (775kg)
1973-1974
Hondamatic
1638lb
(743kg)
1975-1976 Manual
1716lb (780kg)
1975-1976 Hondamatic
1738lb (790kg)
1977-1978 Manual
1687lb (765kg)
1977-1978 Hondamatic
1709lb (775kg)
1979 Manual
1696lb (769kg)
1979 Hondamatic
1711lb (776kg)
