Motor
Specification Information |
Engine Serial Number
VIN are mounted on the top edge of the dash at the windscreen and can
bee seen from the outside. There is also one on the hood mounting
bracket 74-78 Models. 79-83 are on the firewall and rear door jamb. The
first three digits indicate engine model and the balance is production
numbers.
Year/Model
Motor
CC
Bore
Stroke
HP
Torqe
Compression
73-74-1200
EB1
1170
70mm
76mm
50 @ 5k
59 @ 3k
8.3:1
74-77-1200
EB2
1237
72mm
76mm
52 @ 5k
60.5/65*
8.1:1
78-79-1200
EB3
1237
72mm
76mm
52 @ 5k
67 @ 2k
8.1:1
EC
75-CVCC
ED1
1488
74mm
86.5mm
53 @ 5k
68 @ 3k
8.1/7.7*
76-77-CVCC
ED1
1488
74mm
86.5mm
60 @ 5k
76 @ 3k
7.9:1
78-79-CVCC
ED1
1488
74mm
86.5mm
63 @ 5k
77 @ 3k
7.9:1
77-78-Accord
EF1
1597
74mm
93mm
68 @ 5k
85 @ 3500
8.0:1
92-95
SiR (USA)
EG
1595
80-83-1300
EJ1
1335
72mm
82mm
61 @ 5k
68 @ 4k
7.9/8.8/9.3*
79-81-Accord
EK1
1751
77mm
94mm
72/68*
94 @ 3k
8.0:1
80-83-Prelude
EK1
1751
77mm
94mm
72/75*
94/96*
8.0/8.8*
EL
80-83-1500
EM1
1488
74mm
86.5mm
67 @ 5k
79 @ 3k
9.0/8.9/8.8/9.3*
80-83
EN1
1335
72mm
82mm
63 @
5.5k
74@3.5k
8.4:1
81-87
City
ER
1231
66
90
67
@ 5.5k
72
@ 3.5k
10.0:1
City Turbo
I
ER
1231
66
90
100
@ 5.5k
108
@ 3k
7.5:1
City Turbo
II
ER
1231
66
90
110
@ 5.5k
118
@ 3k
7.6:1
1983 Civic 25-i CVCC
EW
1488
74
86.5
100
@ 5.8k
13.2/4,000
8.7
84-85 Civic/CRX
EW1
1488
76
@ 6k
84
@ 3.5k
88-91
Civic/CRX,SI
D16A6
1590CC
75mm
90mm
108
@ 6K
100
@ 5K
74-75 Civic RS
SB1
1169
70mm
76mm
76
@ 6k
10.3/4,000 (kg-m/rpm)
8.6
1972 Civic GL
SB1
1169
70mm
76mm
69 @ 5.5k
10.2/4,000 (kg-m/rpm)
8.6
1972 Civic
SB1
1169
70mm
76mm
60 @ 5.5k
9.5/3,000 (kg-m/rpm)
8.1
**Notes:
74-76 1200= 60.5lb-ft @ 4k, 77 1200= 65lb-ft @ 2k
75 CVCC Sedan= 8.1:1, Wagon= 7.7:1
80 1300= 7.9:1, 81= 8.8:1, 82-83= 9.3:1
80 1500 (all except Cali)= 9.0:1, 80 (Cali)= 8.9:1, 81=8.8:1, 82-83= 9.3:1
79 Accord= 72hp @ 4500, 80-81= 68hp @ 4500
80-81 Prelude= 72hp @ 4500, 94lb-ft @ 3k, & 8.0:1, 82-83= 75hp @ 4500, 96lb-ft @ 3k
& 8.8:1
Additional Information
-73-79 Chassis code was designated SB
-74-77 1200: EB2 motor had 2mm larger bore increasing displacement and power slightly
-78-79 1200: The EB3 was very different from the previous years. The most notable
differences were the domed pistons and the new head (dished combustion chamber and larger
valves).
-75 CVCC: introduced as a way around stricter emissions
-76-79 CVCC: engine was revised internally, producing slightly more power and smoother
running
-The 75-79 CVCC was the only first gen engine equipped with a 5spd transmission (the 1200
would not be able to pull the gear ratio properly) US MARKETS ONLY.
In non US markets the 78-79 1200's could be had equipped with a 5spd
trans. (This model had the deluxe gauges, but did not have the wood
wheel or wood shift knob). of course the Speciail X which also had the
1200 and a 5spd.
-The CVCC's were longer in the nose to accommodate the slightly larger motor (2.17"
to be exact)
-73-79 Civics did not have trim level specifications but were differentiated by their
motor types
More
Engine Codes Here
