First Generation Honda Civic 1973-1979 Service Menu
Index Page 1200 Data CVCC Data Engine Specs. Tranny Specs. Paint Numbers
Main Menu VIN Engine Codes VIN Chassis Codes Engine Timing Service Manuals 1200 Maintenance Schedule
  Oil Types
 1200 Civic Maintenance Schedule
Items Mileage Interval x 1,000 Miles
3 6 12 18 24 30 36 42 48 54 60 66 72
Engine Valve Clearance A .
A
. A . A . A . A . A
Alternator Drive Belt A . I . I . I . I . I . I
Vacuum Fittings, Hoses & Connections . . I . I . I . I . I . I
Engine Oil R R R R R R R R R R R R R
Engine oil Filter R R R R R R R R R R R R R
Coolant . . . . R . . . R . . . R
Cooling System, Hoses & Connections . . I . I . I . I . I . I
Exterior of Radiator Core . . C . C . C . C . C . C
Intake & Exhaust Manifold Tightness Check A . . . . . . . . . . . .
Fuel System Idle Speed & Idle CO A . A . A . A . A . A . A
Choke Mechanism A . A . A . A . A . A . A
Throttle Opener & Control Valve I . I . I . I . I . I . I
Air Cleaner Element . . R . R . R . R . R . R
Fuel Filter . . . . R . . . R . . . R
Intake Air Temp. Control System . . I . I . I . I . I . I
Tank, Fuel Lines and Connections I . . . I . . . I . . . I
Evap. Emissions System Charcoal Canister . . I . R . I . R . I . R
One-Way Valve . . I . I . I . I . I . I
Idle Cut-Off Valve . . I . I . I . I . I . I
Ignition Components Ignition Timing . . A . A . A . A . A . A
Breaker Points . . R . R . R . R . R . R
Spark Plugs . . R . R . R . R . R . R
Distributor Cap and Rotor . . I . R . I . R . I . R
Ignition Wiring . . . . I . . . I . . . I
Advance Mech. in Distributor (4speed) . . . . I . . . I . . . I
. 3 6 12 18 24 30 36 42 48 54 60 66 72
Crankcase Emission Control System
Transmission Controlled Spark Advance . . . . I . . . I . . . I
Brakes Rear Brake A A A A A A A A A A A A A
Parking Brake A . . . . . . . . . . . .
Brake Hoses, Lines,  . I I I I I I I I I I I I
Master Cylinder, Fluid Level . I I I I I I I I I I I I
Brake Fluid * . . . . R . . . R . . . R
Front Brake Pads  . I I I I I I I I I I I I
Front Brake Yoke Performance . I I I I I I I I I I I I
Rear Brake Linings . . I . I . I . I . I . I
Air Filter of Vacuum Booster ** . . C . C . C . C . C . C
Other Front Wheel Alignment . . I . I . I . I . I . I
Clutch Pedal Travel . I I I I I I I I I I I I
Transmission Oil 2-speed/4-speed R . . . R . . . R . . . R
Radiator Fan . I I I I I I I I I I I I
Engine Exhaust Silencer . I I I I I I I I I I I I
Suspension Mounting Bolts . I I I I I I I I I I I I
Steering operation, Tie Rod Ends, Rack Guides I . I . I . I . I . I . I
Grease Steering Gear Box I . I . I . I . I . I . I
A-ADJUST   I-INSPECT,  ADJUST OR REPLACE AS NECESSARY   R-REPLACE   C-CLEAN
*  EVERY 24,000 MILES OR 24 MONTHS WHICHEVER COMES FIRST.
**  EVERY 12,000 MILES OR 12 MONTHS WHICHEVER COMES FIRST.
