First Generation Honda Civic 1973-1979 Service Menu
Index Page 1200 Data CVCC Data Engine Specs. Tranny Specs. Paint Numbers
Main Menu VIN Engine Codes VIN Chassis Codes Engine Timing Service Manuals 1200 Maintenance Schedule
  Oil Types
 VIN Chassis Codes
VIN are mounted on the top edge of the dash at the windscreen and can bee seen from the outside. There is also one on the hood mounting bracket 74-78 Models. 79-83 are on the firewall and rear door jamb. The first three digits indicate engine model and the balance is production numbers.
Year Make Chassis Code Code Model Body Type Displacement Transmission
1973 Civic SBA 1007001-1100000 1200 2DR. EXC Hatchback 1170cc (71 CID) 4Spd. Man.
1973 Civic SBB 1007001-1100000 1200 2DR. EXC Hatchback 1170cc (71 CID) 2Spd. Auto
1973 Civic SBC 1007001-1100000 1200 2DR. Hatchback 1170cc (71 CID) 4Spd. Man.
1973 Civic SBD 1007001-1100000 1200 2DR. Hatchback 1170cc (71 CID) 2Spd. Auto
1974 Civic SBA 2100001-2300000 1200 2DR. EXC Hatchback 1237cc (75CID) 4Spd. Man.
1974 Civic SBB 2100001-2300000 1200 2DR. EXC Hatchback 1237cc (75CID) 2Spd. Auto
1974 Civic SBC 2100001-2300000 1200 2DR. Hatchback 1237cc (75CID) 4Spd. Man.
1974 Civic SBD 2100001-2300000 1200 2DR. Hatchback 1237cc (75CID) 2Spd. Auto
1975 Civic SBA 3300001-4000000 1200 2DR. EXC Hatchback 1237cc (75CID) 4Spd. Man.
1975 Civic SBB 3300001-4000000 1200 2DR. EXC Hatchback 1237cc (75CID) 2Spd. Auto
1975 Civic SBC 3300001-4000000 1200 2DR. Hatchback 1237cc (75CID) 4Spd. Man.
1975 Civic SBD 3300001-4000000 1200 2DR. Hatchback 1237cc (75CID) 2Spd. Auto
1975 Civic SG A1000001-2000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 4Spd. Man.
1975 Civic SG B1000001-2000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 2Spd. Auto
1975 Civic SG C1000001-2000000 CVCC 2DR. Hatchback 1488cc (91 CID) 4Spd. Man.
1975 Civic SG D1000001-2000000 CVCC 2DR. Hatchback 1488cc (91 CID) 2Spd. Auto
1975 Civic SG E1000001-2000000 CVCC 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1975 Civic WB A1000001-2000000 CVCC 4DR. S.W. 1488cc (91 CID) 4Spd. Man.
1976 Civic SBA 4000001-5000000 1200 2DR. EXC Hatchback 1237cc (75CID) 4Spd. Man.
1976 Civic SBB 4000001-5000000 1200 2DR. EXC Hatchback 1237cc (75CID) 2Spd. Auto
1976 Civic SBC 4000001-5000000 1200 2DR. Hatchback 1237cc (75CID) 4Spd. Man.
1976 Civic SBD 4000001-5000000 1200 2DR. Hatchback 1237cc (75CID) 2Spd. Auto
1976 Civic SG A2000001-3000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 4Spd. Man.
1976 Civic SG B2000001-3000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 2Spd. Auto
1976 Civic SG C2000001-3000000 CVCC 2DR. Hatchback 1488cc (91 CID) 4Spd. Man.
1976 Civic SG D2000001-3000000 CVCC 2DR. Hatchback 1488cc (91 CID) 2Spd. Auto
1976 Civic SG E2000001-3000000 CVCC 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1976 Civic WB A2000001-3000000 CVCC 4DR. S.W. 1488cc (91 CID) 4Spd. Man.
1976 Civic WB B2000001-3000000 CVCC 4DR. S.W. 1488cc (91 CID) 2Spd. Auto
1977 Civic SBA 5000001-6000000 1200 2DR. EXC Hatchback 1237cc (75CID) 4Spd. Man.
1977 Civic SBC 5000001-6000000 1200 2DR. Hatchback 1237cc (75CID) 4Spd. Man.
1977 Civic SBD 5000001-6000000 1200 2DR. Hatchback 1237cc (75CID) 2Spd. Auto
1977 Civic SG A3000001-4000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 4Spd. Man.
1977 Civic SG C3000001-4000000 CVCC 2DR. Hatchback 1488cc (91 CID) 4Spd. Man.
1977 Civic SG D3000001-4000000 CVCC 2DR. Hatchback 1488cc (91 CID) 2Spd. Auto
1977 Civic SG E3000001-4000000 CVCC 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1977 Civic WB A3000001-4000000 CVCC 4DR. S.W. 1488cc (91 CID) 4Spd. Man.
1977 Civic WB B3000001-4000000 CVCC 4DR. S.W. 1488cc (91 CID) 2Spd. Auto
1978 Civic SBA 6000001-7000000 1200 2DR. EXC Hatchback 1237cc (75CID) 4Spd. Man.
1978 Civic SBC 6000001-7000000 1200 2DR. Hatchback 1237cc (75CID) 4Spd. Man.
1978 Civic SBD 6000001-7000000 1200 2DR. Hatchback 1237cc (75CID) 2Spd. Auto
1978 Civic SG A4000001-5000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 4Spd. Man.
1978 Civic SG C4000001-5000000 CVCC 2DR. Hatchback 1488cc (91 CID) 4Spd. Man.
1978 Civic SG D4000001-5000000 CVCC 2DR. Hatchback 1488cc (91 CID) 2Spd. Auto
1978 Civic SG E4000001-5000000 CVCC 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1978 Civic WB A4000001-5000000 CVCC 4DR. S.W. 1488cc (91 CID) 4Spd. Man.
1978 Civic WB B4000001-5000000 CVCC 4DR. S.W. 1488cc (91 CID) 2Spd. Auto
1979 Civic SBA 7000001-8000000 1200 2DR. EXC Hatchback 1237cc (75CID) 4Spd. Man.
1979 Civic SBC 7000001-8000000 1200 2DR. Hatchback 1237cc (75CID) 4Spd. Man.
1979 Civic SBD 7000001-8000000 1200 2DR. Hatchback 1237cc (75CID) 2Spd. Auto
1979 Civic SBE 7000001-8000000 1200 2DR. Hatchback 1237cc (75CID) 5Spd. Man.
1979 Civic SG A5000001-6000000 CVCC 2DR. EXC Hatchback 1488cc (91 CID) 4Spd. Man.
1979 Civic SG C5000001-6000000 CVCC 2DR. Hatchback 1488cc (91 CID) 4Spd. Man.
1979 Civic SG D5000001-6000000 CVCC 2DR. Hatchback 1488cc (91 CID) 2Spd. Auto
1979 Civic SG E5000001-6000000 CVCC 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1979 Civic WB A5000001-6000000 CVCC 4DR. S.W. 1488cc (91 CID) 4Spd. Man.
1979 Civic WB B5000001-6000000 CVCC 4DR. S.W. 1488cc (91 CID) 2Spd. Auto
1980 Civic SL A1000001-2000000 1300 2DR. Hatchback 1335cc (81 CID) 4Spd. Auto.
1980 Civic SL C1000001-2000000 1300 2DR. Hatchback 1335cc (81 CID) 5Spd. Man.
1980 Civic SR A1000001-2000000 1500 2DR. Hatchback 1488cc (91 CID) 4Spd. Man.
1980 Civic SR C1000001-2000000 1500DX 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1980 Civic SR D1000001-2000000 1500 2DR. Hatchback 1488cc (91 CID) 2Spd. Auto
1980 Civic SR E1000001-2000000 1500GL 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1980 Civic WD A1000001-2000000 1500 4DR. S.W. 1488cc (91 CID) 5Spd. Man.
1981 Civic SL-332 BS000001 & UP 1300 2DR. Hatchback 1335cc (81 CID) 3Spd. Auto.
1981 Civic SL-431 BS000001 & UP 1300 2DR. Hatchback 1335cc (81 CID) 4Spd. Man.
1981 Civic SK-532 BS000001 & UP 1300 2DR. Hatchback 1335cc (81 CID) 5Spd. Man.
1981 Civic SR-332 BS000001 & UP 1500 2DR. Hatchback 1488cc (91 CID) 3Spd. Auto.
1981 Civic SR-532 BS000001 & UP 1500 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1981 Civic SR-533 BS000001 & UP 1500GL 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1981 Civic WD-352 BS000001 & UP 1500 4DR. S.W. 1488cc (91 CID) 3Spd. Auto.
1981 Civic WD-552 BS000001 & UP 1500 4DR. S.W. 1488cc (91 CID) 5Spd. Man.
1981 Civic ST-343 BS000001 & UP 1500 4DR. Sedan 1488cc (91 CID) 3Spd. Auto.
1981 Civic ST-543 BS000001 & UP 1500 4DR. Sedan 1488cc (91 CID) 5Spd. Man.
1982 Civic SL-431 CS000001 & UP 1300 2DR. Hatchback 1335cc (81 CID) 4Spd. Man.
1982 Civic SL-532 CS000001 & UP 1300 2DR. Hatchback 1335cc (81 CID) 5Spd. Man.
1982 Civic SR-332 CS000001 & UP 1500 2DR. Hatchback 1488cc (91 CID) 3Spd. Auto.
1982 Civic SR-532 CS000001 & UP 1500 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1982 Civic SR-533 CS000001 & UP 1500GL 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1982 Civic ST-343 CS000001 & UP 1500 4DR. Sedan 1488cc (91 CID) 3Spd. Auto.
1982 Civic ST-543 CS000001 & UP 1500 4DR. Sedan 1488cc (91 CID) 5Spd. Man.
1982 Civic WD-352 CS000001 & UP 1500 4DR. S.W. 1488cc (91 CID) 3Spd. Auto.
1982 Civic WD-552 CS000001 & UP 1500 4DR. S.W. 1488cc (91 CID) 5Spd. Man.
1983 Civic SL-431 DSC00001 & UP 1300 2DR. Hatchback 1335cc (81 CID) 4Spd. Man.
1983 Civic SL-532 DSC00001 & UP 1300FE 2DR. Hatchback 1335cc (81 CID) 5Spd. Man.
1983 Civic SR-332 DSC00001 & UP 1500 2DR. Hatchback 1488cc (91 CID) 3Spd. Auto.
1983 Civic SR-532 DSC00001 & UP 1500DX 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1983 Civic SR-533 DSC00001 & UP 1500S 2DR. Hatchback 1488cc (91 CID) 5Spd. Man.
1983 Civic ST-343 DSC00001 & UP 1500 4DR. Sedan 1488cc (91 CID) 3Spd. Auto.
1983 Civic ST-543 DSC00001 & UP 1500 4DR. Sedan 1488cc (91 CID) 5Spd. Man.
1983 Civic WD-352 DSC00001 & UP 1500 4DR. S.W. 1488cc (91 CID) 3Spd. Auto.
1983 Civic WD-552 DSC00001 & UP 1500 4DR. S.W. 1488cc (91 CID) 5Spd. Man.
1976 Accord SJ D1000001-2000000 1600 2DR. Hatchback 1600cc (98 CID) 2Spd. Auto
1976 Accord SJ E1000001-2000000 1600 2DR. Hatchback 1600cc (98 CID) 5Spd. Man.
1976 Accord SJ D1000001-2000000 1600 2DR. Hatchback 1600cc (98 CID) 5Spd. Man.
1976 Accord SJ E2000001-3000000 1600 2DR. Hatchback 1600cc (98 CID) 5Spd. Man.
1976 Accord SJ D3000001-4000000 1600 2DR. Hatchback 1600cc (98 CID) 2Spd. Auto
1976 Accord SJ E3000001-4000000 1600 2DR. Hatchback 1600cc (98 CID) 5Spd. Man.
1976 Accord SJ G3000001-4000000 1600LX 2DR. Hatchback 1600cc (98 CID) 2Spd. Auto
1976 Accord SJ H3000001-4000000 1600LX 2DR. Hatchback 1600cc (98 CID) 5Spd. Man.
1979 Accord SM D1000001-2000000 1800 2DR. Hatchback 1751cc (107CID) 2Spd. Auto
1979 Accord SM E1000001-2000000 1800 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1979 Accord SM H1000001-2000000 1800LX 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1979 Accord SM J1000001-2000000 1800 4DR. Sedan 1751cc (107CID) 2Spd. Auto
1979 Accord SM K1000001-2000000 1800 4DR. Sedan 1751cc (107CID) 5Spd. Man.
1980 Accord SM D2000001-3000000 1800 2DR. Hatchback 1751cc (107CID) 3Spd. Auto.
1980 Accord SM E2000001-3000000 1800 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1980 Accord SM G2000001-3000000 1800LX 2DR. Hatchback 1751cc (107CID) 3Spd. Auto.
1980 Accord SM H2000001-3000000 1800LX 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1980 Accord SM J2000001-3000000 1800 4DR. Sedan 1751cc (107CID) 3Spd. Auto.
1980 Accord SM K2000001-3000000 1800 4DR. Sedan 1751cc (107CID) 5Spd. Man.
1981 Accord SM-332 BC000001 & UP 1800 2DR. Hatchback 1751cc (107CID) 3Spd. Auto.
1981 Accord SM-333 BC000001 & UP 1800LX 2DR. Hatchback 1751cc (107CID) 3Spd. Auto.
1981 Accord SM-532 BC000001 & UP 1800 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1981 Accord SM-533 BC000001 & UP 1800LX 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1981 Accord SM-342 BC000001 & UP 1800 4DR. Sedan 1751cc (107CID) 3Spd. Auto.
1981 Accord SM-542 BC000001 & UP 1800 4DR. Sedan 1751cc (107CID) 5Spd. Man.
1982 Accord SZ-332 CC000001 & UP 1800 2DR. Hatchback 1751cc (107CID) 3Spd. Auto.
1982 Accord SZ-333 CC000001 & UP 1800LX 2DR. Hatchback 1751cc (107CID) 3Spd. Auto.
1982 Accord SZ-342 CC000001 & UP 1800 4DR. Sedan 1751cc (107CID) 3Spd. Auto.
1982 Accord SZ-532 CC000001 & UP 1800 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1982 Accord SZ-533 CC000001 & UP 1800LX 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1982 Accord SZ-542 CC000001 & UP 1800 4DR. Sedan 1751cc (107CID) 5Spd. Man.
1983 Accord SZ-342 DA000001 & UP 1800 4DR. Sedan 1751cc (107CID) 4Spd. Auto.
1983 Accord SZ-532 DC000001 & UP 1800 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1983 Accord SZ-533 DC000001 & UP 1800LX 2DR. Hatchback 1751cc (107CID) 5Spd. Man.
1983 Accord SZ-542 DC000001 & UP 1800 4DR. Sedan 1751cc (107CID) 5Spd. Man.
1983 Accord SZ-732 DC000001 & UP 1800 2DR. Hatchback 1751cc (107CID) 4Spd. Auto.
1983 Accord SZ-733 DC000001 & UP 1800LX 2DR. Hatchback 1751cc (107CID) 4Spd. Auto.
1983 Accord SZ-742 DC000001 & UP 1800 4DR. Sedan 1751cc (107CID) 4Spd. Auto.
1979 Prelude SN B1000001-2000000 2DR. Sedan 1751cc (107CID) 2Spd. Auto
1979 Prelude SN F1000001-2000000 2DR. Sedan 1751cc (107CID) 5Spd. Man.
1980 Prelude SN B2000001-3000000 2DR. Sedan 1751cc (107CID) 3Spd. Auto.
1980 Prelude SN F2000001-2000000 2DR. Sedan 1751cc (107CID) 5Spd. Auto..
1981 Prelude SN-322 BC000001 & UP 2DR. Sedan 1751cc (107CID) 3Spd. Auto.
1981 Prelude SN-522 BC000001 & UP 2DR. Sedan 1751cc (107CID) 5Spd. Man.
1982 Prelude SN-322 CC000001 & UP 2DR. Sedan 1751cc (107CID) 3Spd. Auto.
1982 Prelude SN-522 CC000001 & UP 2DR. Sedan 1751cc (107CID) 5Spd. Man.
